Dyno Test
Old Sep 12, 2005 | 07:45 PM
03YellowPony's Avatar
03YellowPony
Default Dyno Test
Ok, I had the U/D pulleys installed today. I noticed a definate diference. Before, I could not get straight line rubber. Now I can!
I made few phone calls, and found the ONLY chassis dyno in the county! It's in the next town over. Went there and ran the test. Numbers are pertty disapointing. He had to run the test in second gear, and said the rev limiter WAS a factor. Good news is, when I get the 3.73's and T-Lok, they will install for $250.0. PLUS if I bring them the Diablo, they'll make the necessary adjustments for optimal HP output for no extra charge! This shop builds race cars and engines. Made a new friend today! LOL
Like I said, the numbers are disapointing, but will get better. Oh, it's a Superflow Dyno.
[IMG]local://upfiles/17569/791A13A31CFB43769B85064707405149.jpg[/IMG]
Old Sep 12, 2005 | 07:58 PM
HRnB's Avatar
HRnB
Administrator
Default RE: Dyno Test
162 HP. That's not bad for a stock V6 with a few bolt ons. I'm sure you can get those rear wheel numbers close to 200HP with extrude honing and head porting.
Old Sep 12, 2005 | 08:04 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
where did you get the pulleys? i could use a few more horses. to whoop some more ***.
oh, BTW, Booze. Extrude honing and porting are the same thing by different means. extrude honing is done by firing abrasive media through whatever is being ported to port it, and regular old porting is done by hand or CNC machine. and doing it by hand is a BITCH. trust me
Old Sep 12, 2005 | 08:49 PM
Caddstang's Avatar
Caddstang
actually those numbers seem a bit low considering you have pulleys...im guessing its an auto that with a 17% drive train loss you are pulling about 160 stock to the wheels, pulleys alone should have bumped you to at least 168??? hmmm was it hot and humid that day? All i know is that with a cam, ported heads and ported upp/lwr manifolds you should make 200+
Old Sep 12, 2005 | 09:19 PM
03YellowPony
ORIGINAL: matthockey32
http://www.rpmoutlet.com
Old Sep 12, 2005 | 09:20 PM
03YellowPony
ORIGINAL: Caddstang
They had to do it in 2nd gear, and the rev limiter interfered. He said it wanted to keep going, but the limiter wouldn't let it.
Old Sep 12, 2005 | 09:27 PM
matthockey32
I ♥ Acer
ORIGINAL: 03YellowPony
ORIGINAL: Caddstang
damn rev limeter. with better valve springs you can wind that thing out to around 7000 rpms and still be good, i know, i've seen me do it.
Old Sep 12, 2005 | 09:28 PM
03YellowPony
ORIGINAL: Caddstang
The first run they did I SAW it show 172 HP...I don't know what they did to get a lower number.,..but the print don't lie..I guess
Old Sep 12, 2005 | 09:30 PM
03YellowPony
ORIGINAL: Caddstang
I just called RPM..the Diablo should be here by Wednesday..SCREW the limiter..it's GONE, along with the speed limiter!
Old Sep 13, 2005 | 03:59 AM
Caddstang's Avatar
Caddstang
thats good to hear yellowpony [sm=americanasmiley.gif]
