Connector/Module in RH Fender?
Old 01-30-2012, 03:25 PM
Dub9Stang
Dub9Stang's Avatar
Default Connector/Module in RH Fender?
Long story short, i got an electrical issue and its making a weird noise in the right fender when the turn signal is on, it sounds like a flasher. What is that connector/module?? I can see it through a hole where my old intake use to be. It looks like it feeds the maf sensor, air temp sensor, turn signal, headlights, maybe ac compressor, etc etc....
Dub9Stang is offline
Old 01-30-2012, 05:56 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
I does feed the A/C, MAF, Air intake temp sensor, and if I remember correctly the control module for the cooling fan. I do not believe it has to do with the headlights. Those should be coming from over the top of the rad IIRC.
Matthew
Matt's 95 Stang is offline
Gene K
10-21-2015 11:37 PM
8lug
09-21-2015 01:33 PM
zachary1988
09-18-2015 11:17 PM
Sparks_88
09-08-2015 01:06 PM
Tyoung68
08-25-2015 04:31 AM
Quick Reply: Connector/Module in RH Fender?
