Comp cam help
Old Sep 14, 2005 | 08:08 PM
MACHJUAN's Avatar
MACHJUAN
Default Comp cam help
Is this a good choice for a replacement cam. What else would be needed, i'm not that well informed on my valvetrain[&:]
http://www.powerandperformancenews.c...ry_Code=44-CAM
Old Sep 14, 2005 | 10:57 PM
03YellowPony's Avatar
03YellowPony
Default RE: Comp cam help
ORIGINAL: redv6pony
Yup! That's a good one! You might as well change the timing gears and chain while you're at it!
Old Sep 15, 2005 | 10:53 AM
MACHJUAN's Avatar
MACHJUAN
What exactly will the timing gears and chain do? Where can i buy some at?
Old Sep 15, 2005 | 01:22 PM
03YellowPony
ORIGINAL: redv6pony
The upper timing gear it attached to your camshaft. You have to remove it and the chain to replace the cam. You should be able to get the set where you buy the cam. If not, your local auto parts store can get the set. The chain does stretch over time and can affect timing. It's just a good idea to replace since you'll have them off anyway. The set isn't that expensive. Unless you go with true double roller. That's not really necessary.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
junior04
Sep 28, 2015 10:53 AM
