Sequential Tail Light Help
Old Mar 17, 2012 | 04:28 PM
  #41
Paix Wolf's Avatar
Paix Wolf
I fixed it, it was the switch, the braininess twit that owned the car before me taped the connection together and it had come loose, scotch lock fixed that.
Old Mar 19, 2012 | 06:18 PM
  #42
HellSWAT's Avatar
HellSWAT
Back with no good news... The sequential are still erratic... Added more WD-40 to the hazard switch (with no change). GTConcepts said I could buy a new "multi function switch" (which is replacing the entire hazard switch and the entire turn signal stick thingy). I've asked him if he could send me a modified flasher and see if it could change... When I bought the Tridon EP27, the unit only worked half right. The sequential worked fine I think but only lit 2 blubs... (3rd bulb didn't light up so I assume the Tridon EP27 is defective...) Starting to give up... mehh...
Old Mar 19, 2012 | 06:20 PM
  #43
Paix Wolf's Avatar
Paix Wolf
Bit the tridon can only handle 2 bulbs you need to trade the ep27 for one of his modded ones
Old Mar 21, 2012 | 05:55 AM
  #44
robb15033's Avatar
robb15033
Simple answer to original question-
Go to autotrix.net and get a sequential turn signal relay. Be it-
Old Mar 22, 2012 | 07:29 AM
  #45
HellSWAT's Avatar
HellSWAT
If relay meaning flasher than I have ordered it from GTConcepts. Waiting for delivery to confirm if everything works...
Old Mar 22, 2012 | 04:45 PM
  #46
Paix Wolf's Avatar
Paix Wolf
As of right now with the GT Concepts flasher my signals are working fine, like I said before, the problem with my breaks was that the turkey that had the car before me broke the brake light switch's cable and taped it together, 30 seconds with scotch locks and it's all fixed.
Old Mar 23, 2012 | 12:42 PM
  #47
robb15033's Avatar
robb15033
I looked on the website GTconsepts and did'nt see the relay for sale, maybe I missed it. I'm speaking of the square turn signal relay that is under the steering culmn that has 4 prongs that you pull out and push in the new one.
Old Mar 23, 2012 | 01:28 PM
  #48
Paix Wolf's Avatar
Paix Wolf
Yea, that's the signal flasher.
Old Mar 24, 2012 | 12:38 AM
  #49
HellSWAT's Avatar
HellSWAT
You will not be able to see any on sale because I believe it is still in prototype... Or he/she doesn't have mass amount to sell... (reason why me and Paix, are special cases)
Old Mar 24, 2012 | 12:49 AM
  #50
Paix Wolf's Avatar
Paix Wolf
Yes right now hes modifying tridon ep27 flashers so odds are he is still working on them mine was marked modflash001 so I'm assuming he ripped it out of the car he had been testing it in and sent it to me so mine would work
