2.3 ?'s
Old Sep 17, 2005 | 12:14 AM
mustangdude1985's Avatar
mustangdude1985
Default 2.3 ?'s
i got a ? ok im going to bore a 2.3 30 over and was wondering if 30 over 2.3 pistons are 100mm or 75mm or are they 75mm pistons
Old Sep 17, 2005 | 12:43 AM
03YellowPony's Avatar
03YellowPony
Default RE: 2.3 ?'s
ORIGINAL: mustangdude1985
Why not just bore it out 75mm or 100 mm...make it easier.
Old Sep 17, 2005 | 12:45 AM
mustangdude1985
Default RE: 2.3 ?'s
well cause i dont want to go over 30 overbore i only want to go 30 over
Old Sep 19, 2005 | 08:53 AM
wiseguy's Avatar
wiseguy
Default RE: 2.3 ?'s
Check with a piston supplier. There are a lot of them out there, and each one carries a lot of different sizes. Make sure you get the pistons before you bore the engine so that the final bore size can be determined before you open the block up. Your machine shop should know this, but sometimes they just assume that what you ask for is the correct size.
Granatelli Sales
Jan 20, 2020 12:34 AM
Overcast451
Sep 23, 2015 12:18 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
ShaneB26154
Aug 28, 2015 04:47 PM
xr7cougar1968
Mar 17, 2004 02:40 PM
