need help
Old Aug 31, 2012 | 03:53 PM
aaron_strong's Avatar
aaron_strong
Fuel pressure is good maf is clean and 250000 on her
Old Sep 1, 2012 | 07:07 AM
nba1341's Avatar
nba1341
Do you have a vaccum leak or a ****ty cai. I had a backfire with the am 60 dollar cai
Old Sep 4, 2012 | 07:19 PM
rbowmar's Avatar
rbowmar
Wow! you have stumped everybody! Ford, Your Mechanic and (temporarily) the assembled knowledge of the Mustang Forums.
Considering the miles on the car,I'd suggest a new coil pack and plug wires. I have had a couple of 3.8s quit completely after running horribly. A new coil pack and plug wires fixed them right up.
I am sure there are others with more expertise than I.
The one time I had the opportunity learn troubleshooting the rest of the system, My ECU failed with a clear error message, allowing me to bypass a lot of trouble shooting. I don't think this is your problem. When it finally went, it was just like some one reached past me and turned off the key.
Good luck!
Old Sep 4, 2012 | 07:49 PM
StangsTN's Avatar
StangsTN
I had a similar issue that ended up being a vacuum leak.
Old Sep 6, 2012 | 12:42 AM
bmaytum's Avatar
bmaytum
Default need help
I'll take the vacuum leak over the dead ECU any day!
Old Sep 6, 2012 | 10:36 PM
robb15033's Avatar
robb15033
If it's loosing pressure when the cars off, you replace the fuel pump. The check valve is built in.
