O2 sensor related problem/question
Old Sep 3, 2012 | 06:32 PM
ih8unow's Avatar
ih8unow
Default O2 sensor related problem/question
On the last tank of gas that I went through my mileage was down about 40% and right before I filled up my engine light came on. The code was reading P0136 which I thought was the rear sensor and was mainly for emissions control purposes. I decided to go ahead and change the front and rear sensors out on the driver's side and reset the light. Needless to say at around half a tank my mileage was still really low and the engine light came back on.
Any thoughts or suggestions? It is a 1999 3.8 v6. I will also add that my only engine mod is a cai and I just changed the fuel filter at my last oil change around 1,000 miles ago.
Old Sep 4, 2012 | 01:50 AM
bigbenarmy's Avatar
bigbenarmy
First arrived in purgatory, many players may feel not ACT1 pressure, it is easy to pass by. The ACT2 feeling various not suited to the RCC, various. Want to continue into the degree they go elsewhere, team friends with can too, but they could not separate based ACT2. This slightly eased until the 1.0.3 update to buy cheap diablo 3 gold, finally pile of dead bodies over of ACT2, but the burden of the repair is really terrible. Trip down to repair one of tens of thousands is a common thing, people feel very helpless. This time, why not go back to the ACT1 go to enjoy the feeling of rolling? After all, the game is to to the strongest Shuangkuaigan Well buy diablo 3 gold. So then this video let you step out of the shadow of this unpleasant. Since Beta after Kaka as we presented the first video works, I hope you like it. If your progress has been compacted the ACT2 enter ACT3, then the video you when the entertainment a look, and perhaps some locations will let you brighten? Here to help players who also slow progress. Mainly about the the ACT1 various MF point.
Old Sep 4, 2012 | 06:53 AM
BabyGT's Avatar
BabyGT
What the deuce??
Old Sep 6, 2012 | 12:31 AM
Dubwhat's Avatar
Dubwhat
Wow. Spammed by diablo bots
Old Oct 17, 2012 | 04:21 PM
Juan Lopez's Avatar
Juan Lopez
Funny, because there are more bots playing Diablo 3 at this time than there are players! (What a 10 years in the making letdown)
Old Nov 5, 2012 | 02:41 AM
petrock's Avatar
petrock
While not entirely incorrect, the rear sensor does have an effect on fuel trim.
I assume the code was the same, in which case the problem is a wiring issue or an exhaust leak up stream of the sensor. Since its a low voltage issue, if it was a wiring issue either a wire is broken or the signal wire to the sensor is shorted to ground before it gets to the computer.
Good luck...
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
Dathan
Oct 5, 2015 05:52 AM
TfcCDR
Sep 14, 2015 12:08 PM
