LED interior lights?
Old Sep 5, 2012 | 11:17 PM
xtremal's Avatar
xtremal
Default LED interior lights?
Okay so im trying to install led lights for under the seats i wanna put one under the dash and one under the glove box but i want them to light up with the dome lights when i open the door. So how do i connect them?
Old Sep 6, 2012 | 04:01 AM
nba1341's Avatar
nba1341
Wire the one on the passenger side behind the radio and out to the driver feet. Then along with the drive side one hook up the power to the wire that is hot when the door opens (BLK/WH I believe verify with test light)
Then for the ground either hook up a ring terminal to both wires and put it behind one of the metal dash panel screws or you can hook it up to the rear defroster ground if you want.
McLeary
Mar 14, 2016 07:50 PM
andrew1969
16
Jan 8, 2016 02:48 PM
Seanam
Oct 4, 2015 10:15 AM
accarter
Sep 21, 2015 11:56 PM
Colin Ringle
Sep 15, 2015 09:27 PM
