Having Break Issues
Old Sep 16, 2012 | 11:33 AM
Steel_Rain's Avatar
Steel_Rain
Default Having Break Issues
Hey guys, I just put new pads on my car and now the pedal goes all the way to the floor with little to no resistance. I noticed that when you hold the pedal down the brake system hisses really loudly and the cap on the brake reservoir squirts brake fluid. I'm not sure if that alone would cause such an issue but I have a new cap ordered. Any ideas would be great. Thanks
Old Sep 16, 2012 | 01:17 PM
jthorn9's Avatar
jthorn9
The Godfather
You should probably get a mechanic to help you look over the issue. A lot of things could be causing the problem from a bad brake booster, to a bad brake master cylinder, could even be an issue with the brake line or even the caliper.
Old Sep 16, 2012 | 11:08 PM
Daehawk's Avatar
Daehawk
I find a sledge hammer helps me break stuff.
Old Sep 18, 2012 | 05:12 AM
nba1341's Avatar
nba1341
You changed the brakes yourself? Sounds to me like you pushed the calliper piston back without opening the reservoir cap causing fluid to push up and out of the reservoir and also air in the lines hence brake pedal going to floor.
Old Sep 18, 2012 | 10:02 AM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
this. Did you flush the brake lines after changing the pads?
Matthew
Old Sep 19, 2012 | 11:11 PM
Steel_Rain's Avatar
Steel_Rain
Yes I did the brakes myself. I don't remember if I pulled the cap off when I pushed the pistons back in but I think I prolly didn't do that. After going over everything I found the brake master cylinder was shot so I replaced it, bled the whole system and couple of times and now it works like new.
jwog666
Dec 27, 2021 08:09 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
treesloth
Sep 28, 2015 07:03 AM
