next mod?
Old Sep 26, 2012 | 03:30 PM
  #21
wishinsky's Avatar
wishinsky
Ill probably by the right one anyways $50 isn't anything so.
Old Sep 26, 2012 | 05:24 PM
  #22
wishinsky's Avatar
wishinsky
Woooo just purchased a 2003 8.8 28 spline rear end $150
Old Sep 26, 2012 | 06:28 PM
  #23
1slomaro's Avatar
1slomaro
Nice! Know what gears are in it??
Old Sep 26, 2012 | 08:09 PM
  #24
BabyGT's Avatar
BabyGT
Good deal! Thought I did good at 200!
Old Sep 26, 2012 | 08:31 PM
  #25
wishinsky's Avatar
wishinsky
Hell yeah thanks guys for all the help.... and its got stock gears but i have 4.10 on the way.
Old Sep 26, 2012 | 09:21 PM
  #26
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
I would get a new posi unit. Most likely the one on the GT is well worn and a rebuild kit is almost the same price as a new unit. You wouldnt want to go thru the hassel of installing the 8.8 with new gears and a old posi unit. As for as the swap goes its really not that hard.
jack up the car
remove the brakes (including the brake lines)
remove the sway bar
loosen the shock bolts
remove the lower control arm bolts (watch out for the springs)
remove the upper rear control arm bolts
remove the drive shaft bolts (hardest part)
place jack under the 7.5 and wheel it out of the way, wheel 8.8 into spot and reverse the process
Well thats what I remember when I swapped out my rearend. Good luck!
Matthew
Old Sep 27, 2012 | 03:15 PM
  #27
wishinsky's Avatar
wishinsky
Post
jack up the car
remove the sway bar
Matthew
Well I ordered a installtiong kit and new bearings and a tlok rebuild kit with carbon plates
So hopefully it runs like a champ
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
firecoyote
Sep 27, 2015 02:37 PM
