Correct running temp
Old Sep 30, 2005 | 12:42 PM
soccerman58's Avatar
soccerman58
Default Correct running temp
Hi
I suspect I am running too cool in my 89 4-cyl. The temp gauge never reads higher than level with the L in NORMAL, and for the first hour or so of driving it doesn't even creep up that far. Of course, I suspect the thermostat, but I'd like to know what the correct gauge reading should be.
When I used to own a jaguar, we pretty much had to rely on a good stat from WIX to get the Jag to its proper temp consistently. I'm wondering if there is the same sort of deal like this with a stang?
Thanks
Phil
The more things change, the more they change
Old Sep 30, 2005 | 01:31 PM
03YellowPony's Avatar
03YellowPony
Default RE: Correct running temp
I was always told "So long as the temp is somewhere in the normal range". Actually, the temp should be above 180 degrees. For proper emissions related temp, the t-stat should be 192-195. Does this clear it up?? LOL
Old Sep 30, 2005 | 01:36 PM
soccerman58
Hi
Yes, it clears it up. Running under temp looks like a good idea, but it isn't. Now, the question is, what make of stat is known to be reliable for 190 degree operation for this application and where to get one.
Thanks
Phil
Old Oct 1, 2005 | 11:43 PM
Autobadges.com's Avatar
Autobadges.com
Banned
any hardware store will have one. The stock ones are about 192 degrees I believe.
For my setup I use a 180 degree but thats b/c of the engine needing to be cooled way more with a blower
Old Oct 2, 2005 | 12:31 AM
03YellowPony
Stant is most prolific manufacturer. I prefer thier Super Stat. It's more reliable. You should be able to pick one up at your local parts house.
Old Oct 2, 2005 | 12:55 AM
Autobadges.com
Banned
what he said
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Emblazoned
Sep 3, 2015 10:45 PM
