knocking / clunking - Engine
Old Dec 17, 2003 | 08:14 PM
Infuria's Avatar
Infuria
Default knocking / clunking - Engine
ill do my best to describe this....</P>
my 2.3L LX "knock" almost, a very rapid knocking. i popped the hood, and there was coolant splatered all over the left hand side of the engine bay. </P>
There is a small leak in the coolant fill / resivoir. </P>
The knocking usually occurs when the gas pedal is pressed, and the RPMs are in the range of 1500 - 3000 (i didnt want to take it any higher than that)</P>
Also, to add a couple of notes. </P>
1) the heat coming out of the vents is VERY hot</P>
2) the car is VERY VERY sluggish. even for a 2.3L Mustang </P>
3) the car has problems starting up. </P>
4) I changed the plugs liek 2 days ago. the old plugs had severe carbon buildup on them. </P>
i might be able to post soundsif no one canquite figureout. </P>
Old Dec 18, 2003 | 01:50 AM
Infuria's Avatar
Infuria
Ok, so i decided what it would be like to run with-out the front most cylinder? </P>
it sounds EXACTLY the same....acts the same (very very rough idle, shaking the entire car) </P>
tried the same thing with the other cylinders, but they would all cause the car not to crank over. </P>
so i canged the Plug wires, and the disty wire, cleaned the Disty cap. still the same. </P>
pulled the front most plug, looks black. but gapped still correctly. </P>
<IMG src=smileys/smiley5.gif border="0"></P>
needless to say, i havent got the slightest idea. </P>
Old Dec 18, 2003 | 09:32 AM
vfast's Avatar
vfast
I ♥ Acer
are you sure it a knock or pinging....I'm think timing belt
Old Dec 18, 2003 | 03:39 PM
Infuria's Avatar
Infuria
timing belt? </P>
ive been more and more leaning twards head gasket... but i will be alot happier if it was the timing belt.... </P>
</P>
Old Dec 18, 2003 | 04:11 PM
vfast's Avatar
vfast
I ♥ Acer
yep or you have a bad H/G..
Old Dec 19, 2003 | 06:59 PM
Infuria's Avatar
Infuria
Actually i discovered something more interesting, </P>
the spark plug in Cylinder #1 isnt firing consitantly. its very sporatic. i figured this is the cause and soon to be the solution to my issue.</P>
Basically, ive so far replaced: </P>
- Spark Plugs</P>
- Spark Plug Wires</P>
- Disty Cap</P>
- Rotor ( thing inside the Disty cap)</P>
One question... the rotor on the inside of the disty cap, it spins pretty freely, except it will catch on something and actually turn the (what i think is) the actual Disty. </P>
</P>
any insight would be great</P>
Old Dec 20, 2003 | 09:24 PM
vfast's Avatar
vfast
I ♥ Acer
you need to pull the dist..something is a miss...I have my idea but pull the dist. I think you'l see the problem
Nick Oliver
Oct 17, 2018 04:22 AM
67LimeCoupe
Sep 30, 2015 04:46 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Jose Corretjer
Sep 8, 2015 06:32 AM
