IAC or TPS?
Old Mar 28, 2013 | 05:57 PM
Rapscallion Stallion's Avatar
Question IAC or TPS?
2002 V6
135,000
Mods: CAI... and I did the IAC trick to drop rpm's during shifting
Lately I've been having this problem that gets progressively worse. Whenever I come to a stop and the car is in neutral, the rpm's don't go down to the standard 700ish. They stay revved up around 1400 and I've occasionally seen it up around 1700. It's as if the car doesn't know it's stopped.
If I turn off the engine, then turn it back on, everything is back to normal. Then maybe a minute later it will happen again.
Anybody know why this may be? Thanks!
Old Mar 29, 2013 | 03:47 AM
petrock's Avatar
petrock
I’d clean the IAC valve with some carb cleaner. Its probably sticking. I would also clean the MAF with some MAF cleaner. A dirty MAF can cause strange problems.
If you have access to a scan tool that can read live data (available at most auto parts stores) you can read the TPS sensor’s throttle position or percentage. If you get a different TPS position/% when the problem happens, compared to when it doesn’t happen, then the TPS may be bad.
Good luck...
Old Mar 29, 2013 | 09:14 PM
Great advice. Thank you very much!
ShaneB26154
35
Mar 4, 2021 04:05 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
lmurf60
Sep 24, 2015 10:07 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
