Fighting Sending Unit!
Old May 4, 2013 | 08:12 PM
gennss's Avatar
gennss
Default Fighting Sending Unit!
Ok, so my sending unit is bad, (among other issues). So I bought a new one, they're relatively inexpensive. So I remove the previous unit, it has quite a bit of rust (all over the place there's rust).... and then I try to put the new one. It goes in about halfway and... its stuck... So I try to force it... no dice. So I take it out. I try scrubbing the little whole it goes in as best I can and pull out some sediment nothing huge. I try putting th enew one in and no dice, the old one won't go back in either. How do I deal with rusty sockets like that?
I probably have to buy another one I think I rounded the edges of the new one.
Old May 6, 2013 | 08:38 AM
gennss's Avatar
gennss
So any idea how to deal with this type of problem? I don't think I have to get rid of the car for it do I? I think maybe scrubbing it with a wire brush and penetrating oil?
Old May 9, 2013 | 12:26 PM
gennss's Avatar
gennss
help?
Old May 9, 2013 | 12:51 PM
PNYXPRESS's Avatar
PNYXPRESS
what exactly is the issue? reassembling the unit or putting the whole thing back in the tank?
Old May 10, 2013 | 07:20 AM
gennss's Avatar
gennss
Clarification:
Water temperature sending unit. It's like a glorified bolt. It seems both the socket (engine area) and the original were pretty rusty and have debris. I can't get the new one screwed in, it stops about halfway. What is the safest way to fix the problem?
Old May 10, 2013 | 07:50 AM
PNYXPRESS's Avatar
PNYXPRESS
have you tried chasing the threads with a tap?
Old May 10, 2013 | 11:25 AM
gennss's Avatar
gennss
Not sure what that means?
Old May 10, 2013 | 12:41 PM
PNYXPRESS's Avatar
PNYXPRESS
a tap and die set that will cut new threads of clean up the ones that are there
Old May 10, 2013 | 12:57 PM
gennss's Avatar
gennss
Didn't know that existed. That's a brilliant solution! THANK YOU!!!!
Old May 10, 2013 | 01:47 PM
PNYXPRESS's Avatar
PNYXPRESS
You should be able to rent the set from autozone. just be sure you use the correct size tap.
baddog671
Jul 26, 2016 01:20 PM
kevsgt
Oct 9, 2015 10:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
jrrhd73must
Oct 2, 2015 09:17 PM
vbonina
Sep 22, 2015 08:31 AM
