TWO questions
Old Dec 21, 2003 | 01:25 AM
deeStang's Avatar
deeStang
Default TWO questions
Hey i need to know how to change the REAR AXLE SEAL on a 95 v-6 stang?
and i also need to know what parts i would need to swap the v-6 to a v-8?
I just bought a 97 cobra engine...
thanks a lot
Old Dec 21, 2003 | 01:19 PM
vfast's Avatar
vfast
I ♥ Acer
pull the rear cover drain oil, pull off tire,remove shaft pin in carrier,push in alxe remove clip on the end of axle, remove seal. replace seal,put a lil light wt oil on seal lip,check axle for a groove if it has a groove you might want to get a new axle...reinstall axle,put clip back on top of axle and pull axle ,put pin in and bolt in,put some good rtv on pan, bolt up get 2 quarts of syth. gear oil and 4oz or fiction modifirer..
