Speedo cable
Old Apr 15, 2015 | 12:21 AM
blue stang's Avatar
blue stang
Default Speedo cable
How hard is it to replace the speedo cable? A year or so ago I notice what looked like a hole worn through the rubber. Today I was in a traffic jam and the speedometer was bouncing between 0 and 20mph when I was barely going 1mph.
Old Apr 15, 2015 | 03:55 AM
petrock's Avatar
petrock
I’m pretty sure (at least) ’94 and newer mustangs have electrically controlled speedo’s instead of cable driven.
Old Apr 15, 2015 | 07:32 AM
PNYXPRESS's Avatar
PNYXPRESS
The problem isnt the cable. If its like the foxes, the problem is in the cluster.
Old Apr 15, 2015 | 07:35 AM
blue stang's Avatar
blue stang
Ah, I see what tripped me up. I saw they sell gears for the sn95 and assumed that meant it was cable driven. You think my speed sensor is acting up then?
I should also look closer at whatever that was with a hole in it. It came out of the front driver side of the transmission, T5 by the way, and goes straight up the engine bay next to the steering.
Old Apr 15, 2015 | 07:44 AM
blue stang's Avatar
blue stang
You mean the odometer gears? I've already replaced them and everything else in the cluster is electronic.
Old Apr 15, 2015 | 08:23 AM
PNYXPRESS's Avatar
PNYXPRESS
If your odometer works then the issue is with the speedometer motor or gearing. as all that runs off the same electronic signal from the trans
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
Explosive
Oct 2, 2015 07:45 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
