17" wheels/tires for a 2002
My son has a 2002 Mustang with the stock 16" wheels/tires. I'd like to upgrade them to 17". I've found some on craigslist from 2005+ Mustangs. Is this a simple swap? If not, what do I need to do to put on 17" tires?
What he said- they will fit fine. On the fronts they MAy rub the swaybar a bit at full lock. Get a 1-1.25" hubcentric spacer on the rear.
Also- make sure he knows his speedo will read slow! If it says 70, he is doing about 75.
94-16 mustang wheels, regardless of trim (v6, GT, Mach1...) are all interchangeable depending on what size brakes you have. The only difference is the offset which will change how flush it is with the fenders.
Well I did buy a full set of 17" rims off of a 2012. They appear perfect with no scrapes or damage. Hopefully by mid April our weather will be much dryer and I can get it on the road with new rims and tires...WOOT
Thank you for the help.
Gary Ugarek
09-05-2015 09:03 PM
