1998 v6 fuel pump
1998 v6 fuel pump
Hello everyone, I've got a 1998 v6 5speed coupe. I was looking into replacing the fuel pump (I believe the check valve is bad) and I found out that 1998 stangs were a special case where ford was transitioning into a return-less system. So while the 1997 can owners can pick up a nice walbro pump for ~$110, I'm stuck paying $200 for the special pump with an entire new basket...
My question is, has anyone bought a pump for a 1997 and been able to physically fit it into the original basket on the 98's? I know the 1998's also used a resistor to change the voltage to the pump, which will shorten the life of a 97 style pump. I believe I can simply take the resistor out and bypass it so it always gets full voltage.
do you think this will work? has anyone tried it before? I'd rather not run a 255 lph pump in the car since I don't think I'll ever need that much fuel, I wanted to go with a 190 or 155 lph pump, which I cant find for the 1998's...
Delphi pump is available for a '98 V6 at Rockauto.com for $55 + shipping. If you are running a stock fuel system, there is no need for a specialty high output pump. I wouldn't basterdize the fuel supply system if I didn't have to - problems will leave you stranded.
That's all fine, however I have another car I use to get around, and I'm looking to upgrade the pump to a 155 or 190 lph. I will need more fuel in the somewhat near future, so this isn't a problem that will be fixed by replacing with a stock part. in essence I'm trying to convert the fuel system that of a 1997 stang, and upgrade the pump at the same time. I just don't want to buy a 255 lph pump which is about the only upgrade I can find specific to my car
since there doesn't seem to be a lot of information on the subject, I will probably buy the 1997 pump, and do either a write-up or a video of how to make it work. You better believe that if I buy the pump its going into the car... lol
