Automatic racing
Old Oct 24, 2005 | 08:55 AM
mustangman02232's Avatar
mustangman02232
Default RE: Automatic racing
ORIGINAL: HotRods_n_Booze
ORIGINAL: mustangman02232
Well, the first thing I did is make a few changes to get my launch. 4:10 gears, possi, 2600rpm torque converter, trango shift kit and a dual stage Diablo chip to reset my shift points and limiters.
Now I can launch about as hard as a manual and shift faster and firmer than a manual. When I'm racing around, I turn off my trac lock and over drive. I shift at around 6200rpm and never let it drop below 4000rpm.
One very important thing to remember, when you own an automatic trans and you sport shift, make sure to change your fluid and filter twice as often and your trans will last the life of your car.
uh, isnt redline 5500?
Turn off O/D and trac control, O/D also effects the ECU, not just the extra gear, i havent figured out a good way to launch an auto, i tried holding it hard with the break but the rear tires just cut loose
I reset mine to 6300 and I need to bump it to 6500. Also, I have possi and 275/35/18's on the rear, so I get off the lone pretty fast. I need to install my top end stuff now and my acceleration response will improve dramatically.
do you have a cam and lifters, or can the 3.8s actually withstand 6k rpm without any problems? even though i dont plan on tring it, and where are the stock limiters?
Old Oct 24, 2005 | 06:36 PM
HRnB's Avatar
HRnB
Administrator
No, my engine is stock. And yes, the 99+ 3.8's can handle it with no problem because they re -designed the heads which were the weak spot on the older V6's.
Old Oct 25, 2005 | 08:48 AM
mustangman02232
So, where are the stock limiters?
Old Oct 25, 2005 | 01:22 PM
03YellowPony's Avatar
03YellowPony
In the computer.....
Old Oct 25, 2005 | 01:51 PM
mustangman02232
ORIGINAL: 03YellowPony
ok what rpms are the stock limiter set at smartass
Old Oct 25, 2005 | 01:53 PM
03YellowPony
When I went to change mine, it was set at 5500 RPM. But I think that only applies to the O/D and neutral. Because when I was drag racing, I went deep into redline..over 6000RPM.
Old Oct 25, 2005 | 02:02 PM
mustangman02232
shifting manually, or just in drive?
Old Oct 25, 2005 | 02:28 PM
03YellowPony
When I went deep into redline, I was shifting manually..but I did hit just about 6000 in drive on the street a few times....wierdddddddddddddddddddddddd
Old Oct 25, 2005 | 03:22 PM
ByPopularDemand's Avatar
ByPopularDemand
Ive been hijacked
Old Oct 25, 2005 | 04:15 PM
03YellowPony
ORIGINAL: ByPopularDemand
Ive been hijacked
SORRY!!![X(]
mungodrums
Oct 7, 2015 04:01 AM
mungodrums
Sep 28, 2015 05:45 AM
