Exhaust suggestions
Old 02-12-2016, 11:24 PM
Rory Fraser
Rory Fraser's Avatar
Default Exhaust suggestions
hey guys so i want to make my exhaust sound better my only options is to
(A) either straight pipe it no cat no muffler
(B) remove the cats and install an aftermarket muffler
(C) keep cats and change muffler or
(D) dump exhaust at the end of the y pipe
(E) dump exhaust after the cats
what do you guys think will sound the best the muffler i have is some random chambered muffler thats all i know about it oh and i live in BC Canada so emissions isnt a problem
Rory Fraser is offline
Old 02-13-2016, 08:41 AM
PNYXPRESS
PNYXPRESS's Avatar
Leave the cats or go high flow cats and do a true dual setup with a decent muffler.
PNYXPRESS is offline
Old 02-13-2016, 09:34 AM
Rory Fraser
i know dual will sound the best but thats not an option i can only afford one of those options i list above i would like an answer to this question not just get true duels please and thanks if i could affrd them and would be keeping this car for more than 2 years for sure i would drop 500 on duals
Old 02-13-2016, 04:35 PM
PNYXPRESS
PNYXPRESS's Avatar
Well none of your options will make it sound good so either leave it as is or go duals.
Grab a set of tailpipes off a GT and fab up a hpipe. It should cost about the same as the options you listed. Plus won't ruin any resale value the car may have later.
Old 02-13-2016, 09:18 PM
Daehawk
Daehawk's Avatar
B is my choice....well unless you live in a dictator state that does inspections like CA.
Daehawk is offline
Old 02-14-2016, 02:18 PM
Maxstealth04
Maxstealth04's Avatar
Agreed^ I welded my own off road H pipe for mine with glasspacks and sounds good.
Maxstealth04 is offline
Old 02-20-2016, 10:32 PM
Jishikatsu
Jishikatsu's Avatar
Remove the catback and put side exhaust OEM y-pipe, i like that sound more.
If want the one which everyone says sounds powerful.
Remove full OEM exhaust minus Headers and have a shop weld up Dual 2.5" piping into 2 "thrush welded" mufflers(2.5" in/out) that dumps before the Rearend. Make sure they weld on a flange to bolt onto the Headers.
I think thats what the mufflers that originally came on my stang were. If they are, You will not regret it... Unless i got it wrong and they weren't Thrush welded... Then you would regret :P
Jishikatsu is offline
firecoyote
04-11-2020 07:37 PM
vmuth
3.7L V6 Technical Discussions
03-17-2016 06:48 PM
guitarman376
02-11-2016 09:08 AM
UltraBlue91'
02-05-2016 09:47 AM
Dextas' Stang
5.0L V8 Technical Discussions
01-25-2016 06:21 PM
Quick Reply: Exhaust suggestions
