Car drain spec, what does Ford say?
Old 10-31-2017, 08:37 PM
ranger90
ranger90's Avatar
Default Car drain spec, what does Ford say?
2000 V6 base model.
Does anybody know what the specified maximum battery drain is?
I mean, when the car is at rest, not running, no lights, etcetera.
thanks
ranger90 is offline
Old 11-01-2017, 09:25 AM
Daehawk
Daehawk's Avatar
Sorry I cant help. Just thought Id let you know people do see these posts but replies will be slow. I looked and looked but found nothing. You having a slow battery drain or something?
Daehawk is offline
Old 11-01-2017, 07:59 PM
mrwitty_1
mrwitty_1's Avatar
2000 Ford Mustang V6-3.8L VIN 4
Vehicle » Specifications » Electrical Specifications » Battery » Parasitic Draw
Parasitic Draw (Current Drain) Less Than 0.05 amps
mrwitty_1 is offline
Old 11-01-2017, 09:55 PM
Daehawk
Daehawk's Avatar
If its a battery drain it could be your radio if you installed an after market one. Could also be the PCM it says online.
Daehawk is offline
Old 11-17-2017, 12:00 AM
Stepman
Stepman's Avatar
Most likely drain would be the radio amp. Will kill a battery in less than 2 days.
Stepman is offline
Old 11-17-2017, 01:02 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Or an alarm system that is wired incorrectly or a stero amplifier that has it's power inlets incorrectly wires where you plug the antenna wire into an always hot source instead of an acc controlled power source.
Derf00 is offline
