Coolant
Old Nov 21, 2005 | 11:42 AM
V6yellowStang's Avatar
V6yellowStang
Default Coolant
Hey guys. I just bought my Stang 2 weeks ago and the coolant is low. What is the best coolant to use as far as mixture and brand go?
Old Nov 21, 2005 | 01:01 PM
bigwille's Avatar
bigwille
Default RE: Coolant
use distilled water, then mix it with what ever brand you want because there all the same. (not literally). Make sure you dont need a coolant flush before you do that too. Take it to meineke and ask them if you need a coolant flush.
Old Nov 21, 2005 | 01:14 PM
V6yellowStang
Default RE: Coolant
Thanks for the help. By chance do you know the ratio of water:Coolant?
Old Nov 21, 2005 | 01:16 PM
bigwille's Avatar
bigwille
Default RE: Coolant
when you buy the coolant, it says it on the bottle. usually 50:50 I beleive
Old Nov 21, 2005 | 01:24 PM
V6yellowStang
Default RE: Coolant
Thanks. That's what I thought. I wasnt sure if it was the same for these new engine setups.
I have a 75 vette with 350 thats why Im asking
Old Nov 21, 2005 | 01:30 PM
03YellowPony's Avatar
03YellowPony
Default RE: Coolant
I don't know what year your Stang is, but newer ones require Ford's new coolant. It's light Yellow. If you have this, do not, I repeat DO NOT add the green or red. Hell, don't go near the red! Your local Ford dealer carries it, and it's not that expensive. You want either 60-40(60% coolant) or 50-50 depending on your winter temps.
Old Nov 21, 2005 | 01:45 PM
bigwille's Avatar
bigwille
Default RE: Coolant
ORIGINAL: 03YellowPony
by new you mean 05 and up, right? because I have a 2000, and my coolant has the green mixture.
Old Nov 21, 2005 | 01:47 PM
03YellowPony
Default RE: Coolant
ORIGINAL: bigwille
Not necessarily. Mine is an 03, and has yellow coolant. Safest bet is to use the same color as is in it. If you do a coolant flush, use whatever. Unless it's still under warranty. Point is, it's not a good idea to mix the coolants.
Old Nov 21, 2005 | 02:01 PM
V6yellowStang
Default RE: Coolant
I have an 04. I believe it is green, but the expansion tank is pretty low. Also I live in Florida, so should I go with the 50-50 mix?
Old Nov 21, 2005 | 02:52 PM
03YellowPony
Default RE: Coolant
ORIGINAL: V6yellowStang
50-50 is fine
