electrical problems
Old Nov 25, 2005 | 06:26 PM
rob_boura's Avatar
rob_boura
Default electrical problems
my car will start if jumped but wont start on its own tha batery hol;ds juce until you crank it over then dies is the batery done or is the altanator bad
Old Nov 25, 2005 | 06:58 PM
03YellowPony's Avatar
03YellowPony
Default RE: electrical problems
ORIGINAL: rob_boura
From what I read here, it's PROBABLY the battery. Best bet is to get it checked. AutoZone, PepBoys, CSK, most of the chains will test it for free.
How long do you have to crank it til it does start? Does the engine die after you do get it started?
I highly recommend staying away from Exide Batteries. We used to sell them at CSK, and I had a hell of a lot of returns. Delco, Motocraft, and Interstate are good. But when I need a new one, I'm going for an Optima Gel Cell.
Old Nov 25, 2005 | 08:22 PM
rob_boura's Avatar
rob_boura
well i can run it all day on the altinator but when i get back in and try to start it the battery dies i just poped the tops on the batery and the first cell was smokin its a die hard thats about 7 yrs old so is iy definately the battery?
Old Nov 25, 2005 | 08:27 PM
03YellowPony
ORIGINAL: rob_boura
Read PM...
Old Nov 25, 2005 | 10:32 PM
alexr's Avatar
alexr
ORIGINAL: rob_boura
its the battery. after you start the car with the battery, all the electrical units are charged by the alternator. and if the battery is totally dead then it more than likely wont charge. it sounds like you had the same problem i had. the battery just decided to **** out on me and i couldnt start it unless it was jumped, but once it was jumped i could run it all day as long as i didnt have to restart it. i took it straight down to Advance Auto Parts, and for $70 they replaced the battery for me in the parking lot (the battery was $80 and they usually give you $10 back if you give them your dead battery).
jma2
Jul 10, 2023 01:00 AM
ak98
Feb 18, 2023 08:36 AM
uberstang1
Sep 20, 2015 06:42 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
