Fuel pump
I need help !! I have a 90 knotchback 2.3L mustang. I am getting no voltage at my fuel pump. I checked the fuse and its ok, I also checked the connection just before the pump and no voltage. If any of you guys no where the fuelp pump relay is located it would be great. Also if anyone has any hints on where to go from there it would be great!!!!</P>
Thanks <IMG src=smileys/smiley4.gif border="0">, Steph</P>
In the Chilton's manual it says that the fuel pump relay is normally located on a bracket somewhere above the Electronic Control Assembly (I would guess it's Probaly above the computer in the passenger side "kick panel"). The first thing that I would check, is to make sure that the fuel pump inertia switch hasn't been tripped (I would guess that it's somewhere in the trunk, behind a panel).</P>
Hope this helps!</P>
mrappe
Sep 26, 2015 10:16 AM
