Blown Head Gasket
if you decide to get it fixed the labor is gonna cost you a mint, having to take part the whole engine and all. ur best bet would probably be to part out the car. you wont get much for the whole car with a blown gasket, but if you part it out to people that are in need of and/or in search of certain parts you can definitly make a good deal of money. you'd prob get at most like 1 to 2 grand for the car with the bad engine, if youre lucky... im not good with numbers so i dont know how far off that estimate is. but if you part the car out, you could sell the wiring harness for a good amount, sell the exhaust, seats can go for quite a bit, if the dash panel is in really good condition that could be worth some. people are always looking for headlights and tail lights, bumpers, hell, you could probably even get something for a good windshield. parting the car will more than likely get you more money than the whole car with a bad engine. id say part it if you have the time and you either know people that need the stuff or you dont mind working through ebay.
ORIGINAL: Vash the Stampede
drop a v8 in it
drop a v8 in it
See the thing is, is that i don't know how to take the head gasket out and put a new one in....My dad has a hell of a lot of tools.....how much do head gaskets cost??just the parts or kit a really good kit....or i could just run some k7w block sealent through my radiator? and every body says that thiers a lot of work involved in outting a new head gasket in so..
parts to replace a head gasket...not too expensive, around a hundred for Head set and any additional supplies. BUT, since you're going to be in there (if you decide to do it) you may as well upgrade...if money allows. I wouldn't recommend doing a head gasket as a first timer, by yourself unless you have someone with more experience to help you.
ORIGINAL: WhItEvEnOm
well if the parts only cost a couple hundred then why is it like a couple of grand the put them in???
ORIGINAL: ardoller
its very time consuming, practically the whole engine has to be disassembled.
4 hours...TOPS. For a rookie. I've only done a couple, but I would be willing to bet I could have the head off that car in under an hour. Assuming everything unbolted easily. i.e. no rusted parts, no snapping the head off of bolts.
10 hours if you're in the driveway, 12 degrees outside, you don't have any tools, and it's your first time.
Obviously there is a little more involved, but theres no chance of it taking 10 hours.
