new svo help
Old Jan 13, 2004 | 10:01 PM
DaveAllred's Avatar
DaveAllred
Default new svo help
Hey guys, running a new car, 84 svo, heres what i got, can you tell me what this parts do and how they help me out i am tryin to make a list of things for a website, please help thank you, neither pm me, reply, or email me at daveallred@usa.com</P>
</P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">new brakes <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">new left rear rotor <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">complete tune up (all motocraft parts) <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">new RAM clutch kit <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">2 new rear snow tires <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">1987 complete TURBOCOUPE motor <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">new timing belt <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">new thermostat and gasket <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">performance mods and up grades done so far. <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">SACRAMENTO MUSTANG 3inch down pipe <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">GILLIS BOOST CONTROL VALVE <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">K&amp;N CONE air filter <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">K&amp;N breather <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">WALBRO 255 lph in tank fuel pump
BROWN TOP injectors <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">88 TURBO COUPE intercooler <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">RANGER ROLLER CAM anf FOLLOWERS <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">PORTED and POLISHED 87 E6 EXHAUST <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">ALLUMINUN QUADRANT and ADJUSTABLE CLUTCH CABLE <o></o></SPAN></P>
<P class=Msonormal><SPAN style="FONT-SIZE: 12pt; mso-bidi-font-size: 10.0pt">2.5 inch TURBO MUFFLER<o></o></SPAN></P>
Old Jan 14, 2004 | 06:32 PM
DaveAllred's Avatar
DaveAllred
any help
Old Jan 16, 2004 | 10:55 AM
DaveAllred's Avatar
DaveAllred
with all you smart guys tell me something plzzzz
Old Jan 31, 2004 | 12:19 AM
Buzzstang's Avatar
Buzzstang
how much you want for it?
Old Jan 31, 2004 | 12:26 AM
Jugador1's Avatar
Jugador1
I ♥ Acer
the gillis boost control valve lets you easily produce more boost. http://www.boostvalve.comis the guy's site if you wanna read about it.</P>
brown tops are 35 lb injectors...</P>
88 tc intercooler is bigger than your stock one was so it should work better. is it front mount or right by the engine?</P>
3 inch downpipe is the pipe that is leaving the turbo...3in is a good size. </P>
roller cam has less friction and is just better</P>
alum quadrant and adj cable is so your clutch has a better feel to it. the cable should allow you to move the engagement point up or down i believe</P>
Old Feb 1, 2004 | 03:01 AM
DaveAllred's Avatar
DaveAllred
not for sale my friends, unless you got hmmmm 10 grand, hahaha
Old Feb 1, 2004 | 10:51 AM
Buzzstang's Avatar
Buzzstang
interested in some svo? i have a dark sage color 85 1/2 svo that there was less than 50 made interested?
Old Feb 1, 2004 | 02:17 PM
vfast's Avatar
vfast
I ♥ Acer
I got a couple of dollars lets deal
Old Feb 2, 2004 | 07:18 PM
SpeedRicer's Avatar
SpeedRicer
if you're getting a new intercooler, check out spearco fmic's. i've got one on my t3/t4 setup. what size turbo do those run? t3's? either way, if you're getting a different intercooler, why go with another stock one? check out ebay, i got mine for 250. pushes 12psi with less than 1psi boost drop <IMG src=smileys/smiley4.gif border="0">...good stuff. anyway, just my opinion.
Old Feb 2, 2004 | 07:32 PM
Jugador1's Avatar
Jugador1
I ♥ Acer
you can get a "stock" one off another car for cheap. do some research to which is best...http://turbomustangs.com/intercoolers.htm
1996cobraconvertible
Sep 25, 2015 03:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
DaveAllred
SVO Forum
Apr 11, 2005 02:47 AM
perfdesign.com
Jun 26, 2004 12:25 AM
DaveAllred
Feb 29, 2004 01:22 AM
