SCT Install QUESTION
Old Dec 23, 2005 | 07:10 PM
NewMexMustang's Avatar
NewMexMustang
Default SCT Install QUESTION
it says to disconnect the FUEL and ELECTRIC FAN fuses first. then select the file type to load and press select. then turn key on when prompted (do i turn the car on or just like make one turn of the key?). Then it says to make changes to program and stuff but doesn't say when to put the fuses back in? So do you know when I do that?
Old Dec 23, 2005 | 07:57 PM
03YellowPony's Avatar
03YellowPony
Default RE: SCT Install QUESTION
ORIGINAL: NewMexMustang
Make a phone call. There has to be an 800 tech line. Diablo has one.
Old Dec 23, 2005 | 08:01 PM
NewMexMustang
ORIGINAL: 03YellowPony
Ha, didn't even think about that! Thanks Harv.
Old Dec 23, 2005 | 08:08 PM
NewMexMustang
well no 1 800 number but I found an updated manual on their site. It says they had gotten a lot of complaints about the regular manual not being detailed enough.
Old Dec 23, 2005 | 11:31 PM
03YellowPony
NO 800#??? WTF? Glad I went with Diablo now!
Old Dec 24, 2005 | 12:45 AM
Autobadges.com's Avatar
Autobadges.com
Banned
Where did you buy it from? They should be able to help you as well.
Old Dec 24, 2005 | 02:22 AM
Clif Brohn's Avatar
Clif Brohn
Tell me how the chip does NewMex, I am looking into buying the same tuner.
Old Dec 24, 2005 | 05:35 AM
NewMexMustang
Well I found a number and a better manual, but I didn't have time to load it before my gf took it to go wrap it...so I'll have to wait til Christmas now...
Old Dec 24, 2005 | 11:33 AM
justinlm24's Avatar
justinlm24
You do not need to remove the fuses....that is recommened only if you're gonna change your tune often or if you have a pre 1999. They say remove the fuses so it wont drain your battery, but if you're only gonna download the tune then leave it alone it isn't necessary to remove the fuses. When you turn the key just turn it until the radio comes on, DO NOT START IT!!! then you're ready to download the tune or make changes to your settings
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Thrashard340
Oct 15, 2015 11:05 AM
GimpyHSHS
Aug 29, 2015 06:30 PM
toastintx64
Aug 29, 2015 05:12 PM
jdphillips73
Aug 16, 2015 04:34 PM
