How exactly does Nitrous work?
Old Dec 26, 2005 | 08:06 PM
04_Sixer's Avatar
04_Sixer
Default How exactly does Nitrous work?
How long does it last when you spray? Is it a switch or is it a button? Does the Nitrous mix with the fuel in the fuel line? Sorry if I sound like a goddamn dumbass
Old Dec 26, 2005 | 08:14 PM
Autobadges.com's Avatar
Autobadges.com
Banned
Default RE: How exactly does Nitrous work?
Nitrous is usually shot into the intakes..which is best. Its a freezing cold air that flows so fast that it makes hp as more flow = more hp for the engine. Its usually a button you push after you clear the lines (purge) and you usually hit it about 2500rpms when the car is picking up and you have control and towards the power band.
Old Dec 26, 2005 | 09:09 PM
Sonic3v's Avatar
Sonic3v
http://auto.howstuffworks.com/question259.htm
Old Dec 26, 2005 | 09:10 PM
Autobadges.com
Banned
Dude you need to resize your signature..its EXTREMELY LARGE FILE SIZE...slows down the scrolling
Old Dec 26, 2005 | 09:12 PM
Autobadges.com
Banned
My animated signature is 159kb file size
Your animated signature is 2468kb[sm=jawdrop.gif] (about 15x's larger)
Old Dec 27, 2005 | 02:30 AM
jthorn9's Avatar
jthorn9
The Godfather
Also some nos shots are delivered through your air intake, I beleive this is a dry setup, others are delived into your intake manifold, and I think there is one type that is fed directly into your engine, but I'm not sure on that one.
Old Dec 27, 2005 | 01:19 PM
mustangman02232's Avatar
mustangman02232
Dry shot: goes into the air intake (cheapest, easiest to install, less HP)
wet shot: uses extra fuel jets with the nitrous into the intake
Direct port: Nitorus is directed right into each cylender along with extra fuel (most expensive and hardest to install Most HP)
Old Dec 27, 2005 | 03:26 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
it works because n2o breaks down into nitrogen and oxygen (I believe it breaks down because of the engine heat, but I'm not certain why it breaks down) and the more oxygen and fuel you can get into your cylinders, the more power you can make.
FivePointToTheOh
Oct 2, 2015 04:09 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
