turbo
Old Jan 22, 2006 | 10:32 PM
MN1987's Avatar
MN1987
Default turbo
i need a walkthroug for installing a turbo in a 1992 Mustang LX. if anyone can help me.
Old Jan 22, 2006 | 11:26 PM
jgt58's Avatar
jgt58
Default RE: turbo
did you swap out for the turbocoupe motor, if not bye bye motor
Old Jan 22, 2006 | 11:47 PM
MN1987's Avatar
MN1987
Default RE: turbo
do i need to put a turbocoupe motor in it or can i just rebuild it?
Old Jan 23, 2006 | 12:31 AM
03YellowPony's Avatar
03YellowPony
Default RE: turbo
You can rebuild yours using tougher internals.
Old Jan 23, 2006 | 01:54 AM
TBird232ci's Avatar
TBird232ci
Default RE: turbo
tougher internals isnt the issue, its compression
the turbo engines run 8.0:1 compression, the N/A 2.3's run something like 9.5:1 if i remember correctly.
its best to swap the turbo engine in, and work from there
http://www.stinger-performance.com/TechMain.html
look for the article that works best for your application
Old Jan 23, 2006 | 02:48 AM
jgt58's Avatar
jgt58
Default RE: turbo
plus if your stang is a dual plug like mine , thiers alot of work involved to get it to run
Old Jan 23, 2006 | 04:15 AM
MN1987's Avatar
MN1987
Default RE: turbo
oh ok. thanks
Old Jan 23, 2006 | 07:40 PM
Jugador's Avatar
Jugador
Default RE: turbo
ORIGINAL: jgt58
very true. mine is a dual plug turbo that i bought as it sits and i've had it like 2 years and put about 20,000 miles on it and have no idea how they got it to run as well as it does. i didn't think you could tune the stock computer, but it runs so well, i don't see how it's not tuned.
anyway i know youll at least have to find somewhere to feed oil to the turbo and you'll have to put a return back in the oil pan. you'll need an exhaust manifold, downpipe, and the rest of the exhaust. piping to get the air into the intake, and if you're doing a front mount, you'll either have to buy pipes already made or make your own. forged pistons at the least, you should get valves to be on the safe side, and a good headgasket for sure. then you'll probably want bigger injectors and an aftermarket mass air meter. mucho work. just find a donor 2.3 turbo car and swap it if you're that interested in going turbo
Old Jan 24, 2006 | 01:23 AM
MN1987's Avatar
MN1987
Default RE: turbo
what if its a stock turbo from another mustang that only pushes 3 psi?
Old Jan 24, 2006 | 03:49 AM
Mr. Merk's Avatar
Mr. Merk
Default RE: turbo
i havent ever heard of a stock 2.3 turbo running 3psi unless maybe it was one of the old carb'd setups
