turbo
Old Jan 24, 2006 | 10:43 PM
Jugador's Avatar
Jugador
Default RE: turbo
it's not even worth the effort for 3 psi anyway. i would either do it right or not do it.
Old Jan 25, 2006 | 01:39 AM
TBird232ci's Avatar
TBird232ci
Default RE: turbo
ORIGINAL: MN1987
what if its a stock turbo from another mustang that only pushes 3 psi?
Do people ever realize that there isnt a single turbo that doesnt push more than 3psi?
If your turbo bakes 3psi, you have a serious problem, or you need to buy a boost controller. My blown IHI with a bent shaft made 6psi before it locked up.
Old Jan 25, 2006 | 04:07 PM
81ponycar's Avatar
81ponycar
Default RE: turbo
easier to go with 5.0
Old Jan 25, 2006 | 10:53 PM
TBird232ci's Avatar
TBird232ci
Default RE: turbo
ORIGINAL: 81ponycar
No its not.
Old Jan 26, 2006 | 12:00 AM
Jugador's Avatar
Jugador
Default RE: turbo
yeah maybe if you have an 81, but the wiring is surprisingly not bad at all to swap to a 2.3 turbo motor (into the fuel injected 2.3's) and everything fits well because its the same motor. but a 5.0 swap might be easier than a well put together turbo setup added on a stock motor.
Old Jan 26, 2006 | 01:50 AM
TBird232ci's Avatar
TBird232ci
Default RE: turbo
going 5.0, you still need to swap wiring harness', computers, and all that BS
the difference with going turbo 2.3 is youre not changing your motor mounts, youre not changing your throttle cable, youre not changing all your hoses, and all that crap
Old Jan 26, 2006 | 04:39 AM
Mr. Merk's Avatar
Mr. Merk
Default RE: turbo
ORIGINAL: 81ponycar
only if you cant think outside the box....
which i properly named, "The Mullet Box"
Old Jan 26, 2006 | 01:45 PM
jgt58's Avatar
jgt58
Default RE: turbo
ORIGINAL: 81ponycar
[sm=angrymail.gif] and guess what it says , 2.3T rule 5.0's world....
Old Jan 26, 2006 | 02:33 PM
Mr. Merk's Avatar
Mr. Merk
Default RE: turbo
lol
Old Jan 27, 2006 | 08:57 AM
wiseguy's Avatar
wiseguy
Default RE: turbo
Go to www.turboford.net. They have the answers to all of your questions. The site has been having some problems the last few days, but keep trying. You will not believe what these guys do with the engines, turbos, and computers!
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Granatelli Sales
Mar 21, 2016 06:16 PM
TCStangerv6
Oct 11, 2015 05:57 PM
mdj89
Oct 8, 2015 09:16 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
