Headers
Old Jan 27, 2006 | 02:00 PM
  #21
ByPopularDemand's Avatar
ByPopularDemand
Default RE: Headers
ORIGINAL: Autobadges.com
the intake manifolds...you know in the middle of the top of the engine....those tubes that go inward is the upper intake...and the lower is right under it...kinda like a sandwich
What exactloy do I do with those. Port them or is it something else
Old Jan 27, 2006 | 03:21 PM
  #22
Autobadges.com's Avatar
Autobadges.com
Banned
Default RE: Headers
port and polish yes, but I would recommend sending them for the professionals to do perfectly.
May I recommend www.rpm-mustangs.com great sponsor of mine...Mikael is the owner, tell him ShowStang sent you.
Old Jan 27, 2006 | 09:46 PM
  #23
99Stang_V6's Avatar
99Stang_V6
Default RE: Headers
if ya put headers on w/o barely any bolt ons...you'll lose backpressure which will cause loss of torque...which is bad...keep ur torque if any....like everyone else is sayin...wait till you get more air gettin into the engine until you put some headers on...
Old Jan 27, 2006 | 11:29 PM
  #24
ByPopularDemand
Default RE: Headers
So let me get the order straight. Upper and lower intake, then cam, then headers
Old Jan 28, 2006 | 01:18 AM
  #25
jthorn9's Avatar
jthorn9
The Godfather
Default RE: Headers
Yea that would be more like it, but to fully summerize it for you, you'll need to get a 56mm tb (sn95) or a 65mm tb (edge), maybe an 80mm MAM or MAF, depending on your abbriviation and make sure its preset to whatever new fuel injectors you'll get, and then get your upper intake port matched to your tb, and polished, get your lower intake ported and polished, get a performance cam, port and polish your heads, and then get at least 19lb fuel injectors, preferably 24lb, then bring the car to a shop with a dyno and get them to install your new intake, tb, cam, and injectors and reset your air to fuel mixture. You should do all of this at once because doing these mods individually isn't a good idea. Then do headers last because then you'll have enough airflow to justify them.
Old Jan 28, 2006 | 01:33 AM
  #26
ByPopularDemand
Default RE: Headers
Hmm I gotta do all that at once. Can I do UD pulleys(and anything else) first then start a mod fund
Old Jan 28, 2006 | 01:46 AM
  #27
03YellowPony's Avatar
03YellowPony
Default RE: Headers
ORIGINAL: ByPopularDemand
Sure can. Look at my mods, I didn't do them all at once. The only ones I doubled up on was the gears and tuner.
Old Jan 28, 2006 | 11:30 AM
  #28
jthorn9's Avatar
jthorn9
The Godfather
Default RE: Headers
Yes you can do all of the basic bolt on stuff at once, but if you're going to fully upgrade your engine then you should do it all at once, one because it will save you tons of time in money for shop cost, two, you only have to get your aire to fuel mixture set one time, and three, you'll have everything basically free of your engine, so if there are any probalamattic areas you don't yet know about, the shop should easily be able to spot them.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
