same old story
ORIGINAL: jthorn9
Well you have a 5 sp which gives you a big advantage over her auto, so you'll win, but if she had an auto and was a decent shifter things would be different.
try camaroforums.com, one of our sister sites they will probably know what they are talking about a little bit better
ORIGINAL: 03YellowPony
Not much diference, BUT, Irridium's are a longer lasting plug. They're suposed to last 90,000 miles.
EDIT>>
If you really want to wake up the Camaro, go with underdrive pulleys, gears and a tuner.
ORIGINAL: camaroboy17
about those...i was considering ordering some irridium plugs. how much of a diff. do they actually make?
EDIT>>
ORIGINAL: JonBeast
When did you become a Camaro tech?
EDIT>>
EDIT>>
ORIGINAL: tripsevn7
five automotive stores harv? hi pro or gen maint? i knew you were in management, just not the exact field
ORIGINAL: tripsevn7
ok that is nationwide i think, if not they are/were around here at one time.
They used to be called Accu-Tune and Brake. If that rings a bell.
