Good article
Old Jan 30, 2006 | 09:49 PM
Jugador's Avatar
Jugador
Default RE: Good article
na blocks are built just as strong, the only difference in blocks is that turbo cars have oil plumbing for the turbo built in. aside from that, the cast pistons and head/valves and intakes are the main difference between the motors. the reason they have been neglected in the tuning department is that turboing a dual plug motor is pretty much just to say you did it instead of being "the" viable 2.3 turbo option (and most good running dual plug turbos will run a turbo computer instead of the method they used on my car [big mass air/injectors]). eventually if all the 2.3 turbos crack the heads, someone might pay attention to tuning dual plug computers because that will be the best cheap head available, but until then, theyll still suck ***.
Old Jan 30, 2006 | 10:37 PM
alexr's Avatar
alexr
i dont know if i forgot, but what do you have? do you own a modded 2.3 n/a? if so, can you show me a list of stuff done to your car?
Old Jan 30, 2006 | 10:45 PM
Jugador's Avatar
Jugador
nope, dual plug turbo. it's hard to justify modifying a naturally aspirated 2.3 unless you have some badass parts hookups
Old Jan 30, 2006 | 10:54 PM
alexr's Avatar
alexr
yes very true.
Old Jan 31, 2006 | 01:37 AM
alexr's Avatar
alexr
yo jug, u ever see this before? its a sh!tload of work, but it would be well worth it for a 2.3(T) owner.
http://www.geocities.com/_nitro_/vol...volvoswap.html
Oct 5, 2015 06:07 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Sep 3, 2015 07:14 PM
cbird1177711
Sep 2, 2015 04:12 PM
Sep 2, 2015 07:54 AM
