Are these safe?
ORIGINAL: RyansQuick6
Dude, are you just making up opinions without actually doing any research???? It has all been tested and proven to cause zero problems when used in the appropriate dosages. And how in the hell can you compare styrofoam to anything in an engine???? I'll put it to you this way, nitro-methane, in a 30% methanol mix will not melt a dixie cup, but gasoline will.
AT LEAST USE GOOGLEBEFORE YOU MAKE INCORRECT ASSERTIONS ON A SUBJEST OF WHICH YOU KNOW NOTHING ABOUT!!!
I'm puting it in my tank tomorrow, the worst it will do is NOT give me 50mpg, I have no fear of damage. You probably have more than 2oz of WATER per 10 gallons you get at a gas station anyway, and water is very bad for an engine, but even small doses won't hurt anything. I've run r/c car 33% nitromethane mix and water through my intake to clean my engine and the motor didn't even stumble like it would with seafoam, yet it ran phenomenonally better afterwards.
Ryan
ORIGINAL: ZZmustang
Jugador
I don't know if your old enough to remember when they introduced Gas-O-haul. A mix of, I think 5% alcohol with the gasoline. It really messed up all the carburetors that ran it. The fuel pumps and the rubber fuel lines. This stuff may do nothing to the seals and all the rest of the components of the fuel system, I have no Idea, But to say even a small amount "is not going to harm anything." is just not good advise to give people.
Jugador
Ryan
ORIGINAL: FBCBEER
doubling gas mileage
http://www.techeblog.com/index.php/t...ur-gas-mileage
or this, which is using dry ice to get dents out.
http://www.techeblog.com/index.php/t...s-with-dry-ice
Has anyone tried any of these and are they safe?
Would dry ice damage paint?
Would that stuff damage the engine?
around here in the farm belt, there are lots of pre-coolers for produce semi's and u can get dry ice there, if not try a local college or any science lab, they can make you some dry ice, my highschool science lab makes it all the time
v6stang07 you can pic it up at any sherwin williams and, be very carefuly not to get it on your paint, if you do you will be pissed when you what it does, i'm a paint contractor and we use it to get paint off of **** that its not suppose to be on.
ORIGINAL: v6stang07
im doing an experiment overnight tonight...
ill update you on the results tomorrow sometime
i put an injector seal out of a 5.0l mustang in a cup full of nail polish remover
ill see what this does...and ill post the results
ORIGINAL: MEM 302 5.0L
