Weird Noise...
Old Nov 7, 2007 | 11:12 PM
hpwrestler220's Avatar
hpwrestler220
Default Weird Noise...
idk what it is but i was driving today and i made a slight turn right and there was this squeeling noise. not the noise when you turn the steering wheel fully to the right or left. this was like an actual squeeling noise. i cant get a good explanation of it but what could it be??
Old Nov 7, 2007 | 11:31 PM
l_shizzle_l's Avatar
l_shizzle_l
Default RE: Weird Noise...
Did you run over something? Maybea cat under your hood???
I don't have the slightest clue.
Old Nov 8, 2007 | 11:41 AM
hpwrestler220
ORIGINAL: l_shizzle_l
lol... idk wtf it is. hopefully it went away by today so that when i start my car and drive, it wont do the same thing to me again
Old Nov 9, 2007 | 04:33 AM
Whitie's Avatar
Whitie
Could be your power steering pump starting to go out.
Old Nov 9, 2007 | 10:31 AM
mcfarway's Avatar
mcfarway
If it makes the 'squeal' all the time, then you can diagnose ... if it's intermittent, then it's more difficult. If it's only when you're driving, then it's probably suspension, if it can be duplicated when you're stopped (just turning the front wheels) then it's probably the serpentine belt or P/S pump (remote chance). Noises seldomly 'go away' ...
Old Nov 9, 2007 | 11:09 AM
hpwrestler220
ORIGINAL: mcfarway
yes. it seemed to have gone away lsat night when i was driving it thank God.
nice car btw mcfarway.. get some tinted headlights...
Old Nov 9, 2007 | 12:08 PM
johnt2k7's Avatar
johnt2k7
what kind of sound a whine or a squeal
a whine is usualy a bad ps pump or a ps pump out of fluid
and a squeal could be the belt when you make the ps pump work and you have a bad belt it will actualy make the belt squeal some times
Old Nov 9, 2007 | 12:27 PM
hpwrestler220
ORIGINAL: johnt2k7
i really dont know what it is.. its a squeal. its not the PS pump bc thats the sound when you turn the wheel all the way.. its not the belt. its coming from like the right front tire it seems when i move the steering wheel about a 1/4 of a full turn
Old Nov 9, 2007 | 08:13 PM
johnt2k7's Avatar
johnt2k7
no when a power steering pump is running low on fluid or has run low and has been re filled it will whine almoust like a supercharger sound because the pump cools and lubricates its self by the ps fluid and it that runs out you will ruin the pump and it will whine
the sound you are hearing when you cut it the whole way is the relief valve becase if that wasnt their and you turned the whole way and held for a sec or 2 you would blow the ends out of the rack and pinion just like you would do if you stepped on the brakes when the calipers where off or if the rear shoes where off you would blow the pistons right out
Old Nov 9, 2007 | 11:56 PM
hpwrestler220
ORIGINAL: johnt2k7
im learning a lot from you lately... dont u go to an automotive school or something??
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
mungodrums
Sep 28, 2015 10:54 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
MasterLanMan
Sep 13, 2015 08:21 PM
