Cam?
Old Feb 5, 2008 | 08:31 PM
silkj9's Avatar
silkj9
Default Cam?
ok i know my car is only a V6 but its true dual (x-pipe) and i'm looking into getting some new headers. i was talking to a friend and he said i should look into getting a camshaft. what i wanted to know is that because my car is a v6 would an aftermarket camshft be something for me to look into.
Old Feb 6, 2008 | 06:31 PM
Daytripper540's Avatar
Daytripper540
Default RE: Cam?
Yeah. A Cam will make your car sound awesome, and will give you quite a few HP if you get the right one. Someone on here will be able to tell you more.
Old Feb 6, 2008 | 06:35 PM
mstang420's Avatar
mstang420
Default RE: Cam?
im looking for more information on this too ^
Old Feb 6, 2008 | 07:53 PM
cobra232's Avatar
cobra232
Default RE: Cam?
a cam on a stock engine will get maybe 20-25hp. port the heads and intakes and almost double the power like a 40HP gain maybe more.
you can get a nice lope to you car too but you will probably need steeper gears and a stall converter if you go with a bigger cam.
www.delkperformance.com and www.supersixmotorsports.com can supply a nice Comp cam for your desired engine setup. matt neuharth From delk can really spec out a custom grind and it's about the same price as an off the shelf comp cam.
you can get a V6 cam through jegs or Summit as long as you have the part#.
you also need valve springs for the higher lift and it is wise to get hardened pushrods.
it won't be cheap at all especially the install
Old Feb 6, 2008 | 09:29 PM
mstang420's Avatar
mstang420
Default RE: Cam?
what kind of labor cost do u expect ?
my friends dad actually said he would install the entire package for 400, lol
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
