stangant's engine build thread
unfortuanlty I am almost at a stopping point, I am waiting on the supercharger and adapter and then money to buy the exhaust parts. Currently only have the MAC pro dumps which will be a temp setup... maybe... haha. Have to put the pins in the rack and pinon arms then the wheels go on. Installed the new throttle cable, clutch cable,60lb injectors, heads are torqued and all the accessories are on which are now nothing just the alt.
Need to do the fan wiring and the fuel pump wiring and install the duel pumps.
officially at a stopping point until the sc and adapter are here along with the last bit of exhaust.... Unfortunatly once the tires were on i noticed that the the front tires seem to have the toe in... with the driver side straight the passanger side is pointing inward. I am thinking i need to get under and unbolt the steering shaft and rotate it just a bit to get it back then get the Steeda bumpsteer kit.... ugh i need money.. haha
in this shot the passenger side is straight and drive is toed inward.
That you mention that, the stock ones cracked and I am awaiting them.
I think it's currently an issue with the caster camber plates as well, they need to be lined up i guess. They are currently the same on both side but i will see.
