overhead heat
Old Sep 15, 2014 | 10:09 AM
driftking1921's Avatar
driftking1921
Default overhead heat
I have an 03 5speed v6 mustang and had an engine light come on. I had it tested at autozone..they said it's the overhead temp reading..what's this mean exactly and is it something big to worry about cuz I just started financing this car less than a week ago help plz
Old Sep 17, 2014 | 07:31 AM
BabyGT's Avatar
BabyGT
Let us know what the actual code number was, sounds like a bad sensor or something. Does the temp gauge in the dash seem to work?
Old Sep 17, 2014 | 10:32 AM
dawson1112's Avatar
dawson1112
Over head temp reading would infer the outside ambient air sensor..... Do you have a gauge that tells you the current outside temp?
Like the cars that have a compass and information center.
I agree with BabyGT get the actual code number that they retrieved, I don't know to much about the v6 mustangs in 03 but I did not know they had an over head information center in them.
Old Sep 18, 2014 | 06:42 AM
BabyGT's Avatar
BabyGT
First I've heard of an info center, and that wouldn't not trigger an engine light if it messed up anyhow. Only drivetrain critical issues would. I haven't played with the engine wiring in my 04 but I would hazard a guess that there is a separate temp sensor for the computer and the in dash gauge. If the in dash gauge is working then id assume the other has gone bad.
Old Sep 28, 2014 | 01:09 PM
driftingisfun17's Avatar
driftingisfun17
Ok here are the codes that popped up and this is after cleani bg the crank sensor and doing the plugs and wires
P1299
P0300
P0340
P1336
P1270
P1285
Old Sep 30, 2014 | 09:27 AM
BabyGT's Avatar
BabyGT
I'm gonna go out on a limb and say you forgot your password and instead of doing a password recovery you just started a new account.
Old Sep 30, 2014 | 09:38 AM
BabyGT's Avatar
BabyGT
P1299 is the computer temp sensor getting an abnormal reading, either car overheating or bad sensor.
P0300 is multiple cylinder misfire, likely bad coil, wires, or plugs, or combination of those three.
P0340 is cam position sensor, $20 dollar part on top of engine behind water pump.
P1336 links back to cam position sensor as well, see previous.
P1270 is speed limiter reached, either you are ******* the **** out of it, or the previous owner did. Clear out with a scanner and that's set.
P1285 goes back to that temp sensor again. Either you have air in the coolant system or you need to replace the sensor.
Old Sep 30, 2014 | 09:40 AM
BabyGT's Avatar
BabyGT
Looking at the fact that you're getting two codes for the cam shaft position sensor being a problem in willing to bet that the misfire is due to the sensor being bad/misaligned as well. Sounds like a new cam shaft position sensor, and possibly a coolant air purge or new ecu engine temp sensor will solve your problems.
Old Sep 30, 2014 | 09:42 AM
BabyGT's Avatar
BabyGT
And if you're still financing this thing id go back to the dealership and tell them they need to fix it/replace the car/give you a refund, or you are going to the better business bureau sounds like they just cleared the codes before they sold it knowing they were selling a lemon.
PaulH2
20
Jan 31, 2016 09:48 AM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Art161
Sep 9, 2015 10:33 AM
