fog light switch question
I installed a gt front bumper and lights on my wifes v6 this past week. I ordered the complete wiring kit from street scenes and have everything hooked up and working fine. I had a little trouble with getting there switch to mount in the hole i drilled in the headlight switch panel and ended up having to use a little super glue to get it to hold. Not crazy about the way it came out so i just went and bought a gt headlight switch. There are two wires that go to the add on switch of which one splices into the red and white on the factory switch. I am wondering if i can use the gt switch by just simply splicing the other wire into my existing harness? I'm not sure which wire i would have to splice into however. Can someone give me some instruction on this. I have looked at a couple wiring diagrams but to be honest i can't really make much sense of them.
Thanks
Kerry
Thanks
Kerry
RE: fog light switch question
got this figured out thanks to Afixer. Since i already had the street scenes wiring harnes in the car all i had to do was disconnect the ss red wire from the factory red/white wire. Then spice the incoming yellow wire from the kit to the orange/green wire in the factory plug. Now i have the actual gt headlight switch working.
Diode Dynamics
28
05-26-2022 12:02 PM
bond007
08-26-2015 11:36 PM
inyadreems
08-21-2015 09:10 AM
