lca's and panhead bar installed
didn,t pull cats off, their still in their stock spot, put the X-pipe right about where the "Y" starts, then my 2 cheapey magnaflows...
ORIGINAL: omer333
you're running an x-pipe with the cats? interesting...
the cats performance wise just restrict a bit of flow. .. so cats being there or not dont really have an affect on a X-pipes function
question, lol... didnt wanna start a new thread for this..... cuase it prob was answered already in this but i figure i at least look, lol...
are lca's an easy install/upgrade to perform w/ basic hand tools in a driveway or anything?
ORIGINAL: Puleo76
torque wrench (set everything to 75#)
15mm & 18mm wrenches and sockets
rubber mallet
grease gun
I thought install was easy, put the front part of new control arm in first, its a tight fit, then you can push the axel fairly easy to get rear lined up, everything together at one time should be able to do in an hour, the new BMR lca's I installed were almost half the weight of the stock ones but they make a big difference, with the panhead bar replacement as well, the rear doesn't fell "soft", I tested it out on some curvy road and some quick take offs, only thing is the "soft" front is seemingly more noticable, LOL, more stuff on the list, one other thing is they make some noise for some reason[sm=WTFsgign.gif]
Sep 1, 2015 08:16 PM
