Hellwig rear Anti-Sway bar install w/pics!
#25
RE: Hellwig rear Anti-Sway bar install w/pics!
ORIGINAL: Sancho805
for V6's, only the PP's come with arear sway bar. I believe its 18mm thick. The stock GT rear sway is 20mm thick.
#26
ORIGINAL: So_Cali
Yea thats what I thought, I knew regualr 6's didnt have any sways. So am I better off getting both front AND rear or will the rear be enough to feel a substantial difference?
ORIGINAL: Sancho805
#27
ORIGINAL: 06roushv6
actually, all 6's come with a front sway, but the rear is only standard on the PP
#29
YES IT WILL!!!. i currently only have the rear gt sway installed (20mm) along with the factory v6 front sway (28mm) both with factory rubber bushings and i felt a significant difference with the added rear. car stays pretty level when cornering and it really feels like it grabs the road much better. i will be purchasing some poly bushings this weekend and will replace the rubber bushings on the rear. i also have the GT front sway laying in my garage and will install that one as well once i get all the poly bushings i need. should be an even bigger difference.
