UGLY top speed
RE: UGLY top speed
ORIGINAL: Trill Gear Head
CAI & X-cal 2 tune
CAI & X-cal 2 tune
RE: UGLY top speed
also you will want to make sure you get a good tune dont plug it in and then start messing with the setting on the x-cal/diablo and +1 you dont need a cai (cold air intake) but you will see a big improvement.
go with the C+L (intake) and x-cal2 (around 550$)
also dont kill yourself who needs to go over 113 anyway i thought about it and i dont really want to risk it here in america.
RE: UGLY top speed
on the SCT tuner, you have to go into user options, scroll down thru the different options, you'll come to rpm limiter, rpm2 limiter, and then topspeed limiter. Caution, the speed limiter is set at 112mph by Ford to protect your *** from a tire blowout. Your factory tires are only rated to the upper 90's mph. Even with built in safety factor of 10-15% when new, you risk tire blow out at speeds over 100mph... don't matter if your wearing seatbelts, airbags working or not...your more than likey to kill your self and someone else too.
Be advised, a traffic ticket at those speeds is not a mail in fine, it's a go to jail, post bond, get your nice new care towed, scratched up, rummaged thru, and stored at impound lot, at least $150 to $300 to get out, not to metion the points on your revoked lic and the crap you'll get from your friends whom will see you standing at the bus stop waiting for a ride to work. ;(
Be Carefull please
Be Carefull please
RE: UGLY top speed
ORIGINAL: Jetbo
You will want to make sure that your tires are rated to handle what ever you set your new max speed to btw.
RE: UGLY top speed
Info provided from www.Tirerack.com The stock tires that came on my GT were Z's
Speed Ratings What are these?
WARNING!!! V is the minimum recommended speed rating for non-winter tires.
None
P - 93 MPH
Q - 99 MPH
S - 112 MPH T - 118 MPH
U - 124 MPH
H - 130 MPH
V - 149 MPH Z - 149+ MPH
W - 168 MPH
Y - 186 MPH
