Collision
RE: Collision
Bigger issue is you missed a "soft object" and hit a "hard object". Definetly take it to a body shop for an estimate (freebie). They will also tell you if there are safety concerns. Trust me. When you've seen a wheel come off with the control arms still attached it aint pretty.
RE: Collision
ORIGINAL: amystery2u
That has been one of my concerns, even though I don't see it likely happening. I'm going to take it in a few days... Atleast if the wheel fly's off I can hope that it erases all traces that this could have been my fault .
RE: Collision
ORIGINAL: localgod11
Can someone please explain to me what is the attraction with dog and these cars?? this is the second time I have read of this happening. Do a search I cant remeber the guys name right now but he had the some problem you did, with the dog and the wheel.
I do remember seeing that thread a couple weeks back, but the accident was much worse and it rendered his car undrivable.
RE: Collision
ORIGINAL: ST4NG
If (God forbid) your control arms are damaged and fail, at speed it will rip through your break lines like a knife through hot butter, then you are only left with an e-brake and no steering.
Granted I wasn't there and have not seen the damage first hand. I always operate off the worst case scenario.
Hope it's a cheap fix. Good luck.
RE: Collision
if indeed it is the control arms I had mine replaced yesterday for mine being bad....I only have had this mustang for 2 months ...... I had not hit anything my control arm was grinding and popping so I got a whole new suspension and control arms...and struts for free....so you might see if yours were apart of the ones that came out bad...my dealership said there are quite a few coming in and getting fixed ....my car is 1000000000 times better ( as far as noises and the ride) it would be worth asking ....if they ask what dealership has been having problems tell them Joe Cooper Ford in Midwest City has had problems with the control arms
RE: Collision
Well I took my car down to a local auto collision center today.
I was told that the best case would be an alignment. The guy also informed me that with an alignment they could tell me exactly what has been damaged. With the alignment he said it is possible that they can correct it. The worst case he was talking about a nice $2000.
RE: Collision
my bet is the lower control arm! here is a pdf of the suspention
http://www.2005stang.com/gallery/alb...ded%20view.pdf
RE: Collision
If a deer is a small animal I wouldn't want to see what they consider a bit animal! I has a 'small deer' with my Mustang about two months ago and it did just over $3000 of damage. I think deer are like dogs, they are both suicidal. The deer was hiding in a small thicket of trees and jumped out right in front of me. The stupid thing couldn't wait just two more seconds to just, I would have missed it then. Now I drive a truck to work and only venture out in my Mustang on weekends. Personally I think there are better ways to control the deer population than using cars. I hardly go more than a week or so without either seeing a flattened deer on the road or hear about someone I know that's flattened one. Deer are a real problem here in Northern Virginia. Me, I would rather run down a dog than a deer any day. Even big dogs are smaller than the 'small deer'.
