thought i blew something last night ( new title)
well i was going at it with a gt(intake and exhuast) up to 80 . cause i knew at around 80 mph and above 5200 rpm i will run really lean. SO i knew to stop around there. Now when i stopped i hard a rather differnt sound then my woosh. there was no ..(sssshhh)... ok with that said
it idles fine. but if i floor it it goes through the rpm slow and doesnt really pull and the eninge is loouder then the charger and I cant hear it. those are two things i notice. anyone with FI knows what i mean you know how fast i goes through it and 1st and second.
what did i possible do it.. I dont think it denonated. How would it run if i "blew a piston" seems to be the IN thing....
its to late for me to look at it to see if something is visual jacked. If i rev it sounds normal just doesnt run hard like its suppose to .
the tune is fine untill WOT @ 5200 around 80mph then leans out pass that idles fine and revs fine.
ANY techs can help.... scrming, rygen, jimp, anybody else familiar
RE: god DAMNNNN
hopefully your cat didnt fall apart and plug up. If it did, you can create too much backpressure and kaboom. Ask don_w, he had a cat melt on his gt, and blew his motor into pieces. any check engine light, sputtering, misfiring?
RE: god DAMNNNN
Hmmmm......when Scrming lost a pistion he said the engine was extreemly loud!!!! Like a deep clanking noise I believe. So you know when you blew a piston, its loud as hell. I remember when I blew on e on my POS 84 accord when I was 19, same thing.
Maybe your engine is fine, I'm wondering if you damanged the charger. Not sure. When you drive it, does it drive like you did NA? Fazm is right, you might want to talk to Don_w.
RE: god DAMNNNN
Do a compression and leakdown test on the cylinders right away, that will tell you if you have any piston, ring or valve damage (any of which can be damaged by a lean condition). The problem with detonation is sometimes it is silent! I burned a valve in a car once and it did not idle smoothly, plus the check engine light would not go off. Since that is not happening to you, hopefully your motor is OK. But you should still check it out ASAP. If it fails either test, you'll have to pull the heads to see what the damage is.
When you say "and the engine is louder then the charger and I cant hear it", is the motor louder than it was before or is the SC quieter? If the motor is louder; is it clattering, knocking or making any other noises it wasn't before?
RE: god DAMNNNN
ok morning came and woke up after no sleep last night cause i couldnt get the car outta my mind...
Pop the hood. and start looking for something on the block, heads, any type of fluid ... nothing ..... look at the charger fine... hummmmmm
turn enigne on ....[sm=dontgetit.gif]..... ok turn off.... then i get the idea ill check the piping. welll...
The pipe coming down from the charger itself came loose. after a month in a half it came loose..... . reconnected and started up and took it for a spin.... everythig is fine now... i guess all this blew a piston had me scared..
RE: god DAMNNNN
ORIGINAL: afixer
bob take this as a warning ! get that thing tuned you got lucky this time!
RE: god DAMNNNN
i am i.. no more "funny buysiness" lol untill i get that daiblo maifa piece... but as far is running lean .. when i get back to post on monday and scan tmy dyno yall can se my pull.. the tuner said it leans out only at wot in the 80 mph range.
RE: god DAMNNNN
ok... just a quick comment here... Scott confirmed that I was getting plenty of fuel with the Vortech (using 39# Terminator injectors). The Vortech comes with a 4 inch MAF housing...
Glad to hear it was just a loose tube!!! PWHEW!!!
