RP Oil
Old Jun 3, 2006 | 03:32 AM
Erdrickk's Avatar
Erdrickk
Default RE: RP Oil
ORIGINAL: fazm
Oh and the transmission holds 11.9 quarts (includes lines and cooler). So i would recommend at LEAST 13-14 quarts on a flush.
Is that for the Manual Trans? I called ford and the mechanic said 5 Litres would be enough
Old Jun 3, 2006 | 03:33 PM
thatstang's Avatar
thatstang
Default RE: RP Oil
From my old mechanics days we beleived flushing manual trans fluid is a waste of money as long as you change it regularly. I can see the benefit of flushing Auto since most of the fluid is stuck in torque converter and cooling lines but for Manual, you get most of it if you just drain it. I also jacked my car on the driver side while draining to get as much out as possible. To fill manual, you can get a special plustic pump from Kragen that sells for 6.99 and can be screwed on to any quart bottle. Easy fill.
wraith777
Sep 28, 2015 10:49 AM
Shadow7874
Sep 24, 2015 09:06 PM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
kevsgt
Sep 9, 2015 06:20 AM
