removing and Painting the calipers
RE: removing and Painting the calipers
I bought Duplicolor caliper paint from autozone. It comes in a can not a spray so that you don't have to remove the calipers. Worked great but don't use a brush! It made streaks and was hard to keep even so instead I used a cotton shirt and using my finger applied it evenly on the caliper. It came out great! I used the jack that came w/ the car and although it takes time it does work.
I did mine with a spray can and it came out perfect. I'm getting some pictures soon so I'll post them soon. I really had no problems with the spray and it only cost $3.50 plus I bought some brake cleaner. Saved lots of money and looks great.
Question, does anyone know where to get letter or stickers to put on the caliper?
ORIGINAL: rmays06
And I heard that when painting the calipers from a can, the best brush to use is like a slant edge sponge tip.
Yeah, you can mask it off and paint. Use the highest temp engine enamel (1500 degree) you can find, and use 4 or 5 coats. Remember to let them get tacky between coats, and clean the caliper really well. Use break cleaner and maybe even a light grit sand paper.
ORIGINAL: paulboy16
yah i was wondering if u could mask it and paint it while there on there..... what ever u can see u can paint right???!
Paul
Paul
