Exhaust Vibration TSB's
JUSTIN,
I'm looking at duals on your car and if the TSB is for the stock exhaust, I don't see how the TSB would even apply. It's not a matter of "voiding your warranty", the parts affected aren't even on the car anymore. Just a thought. It sounds like a trip to the original exhaust shop is in order.
Search TSB 06-4-1 for the Center Stack Rattle fix (that's the hose clamp one). Before the factory exhaust pipes Y together there is a hanger on each side through a rubber mount attached to the tranmission cross member. You put a 3" hose clamp around the entire exhaust pipe and over the bushing and tighten down...that's it.
TSB 05-8-6 is for 850 RPM vibration for 4.0 V6 w/ auto tranny.
ORIGINAL: Dean Martin
Thanks,
Mike
