Rolling Down windows with key remote?
I saw this in the 2005-2006 section so I figured Id post it over here, I tried doing it but mine doesnt work it says any car built before May of 05 will have it, so im going to make an appointment to have them try to make it work, To do it you have to hold down the unlock button for a few seconds and your windows or window will go down, it should be in your manual.
RE: Rolling Down windows with key remote?
ORIGINAL: fazm
It only works on the cars installed with the upgraded ford alarm The global something something one.
no
here is a quote from an old thread
You guys are talking about the problem which caused Ford to remove the "Remote Window" function of the remotes.
Also tells me that your cars were made before May of 05.
You have the ability to lower your windows with your remote... but - there is something wrong with that function.
If it bothers you too much - take your car to your local Ford dealership and they can disable the function. But if you do that, you will no longer be alble to lower your windows with your remote control.
From mid January to May, Ford left the function, but factory disabled it... after May, they removed the function entirely.
https://mustangforums.com/m_1047347/tm.htm
^^^^ ORIGINAL post
https://mustangforums.com/m_1550344/tm.htm
^^Post in the '05 + section
^^^^ ORIGINAL post
