new street scene factory style center light kit for the v6
#22
RE: new street scene factory style center light kit for the v6
ORIGINAL: localgod11
Any idea if the kit will come with the lights and harness to make it work?
#27
lx this is the one i have now, it is a composet shell with a powder coated steel grill insert. i also have the lower grill to match. soo the complete package is the harness, grill and lower grill. you would also need to get the lights. they are around 39.00 each. so
269.00 grill
87.00 harness
78.00 lights
79.95 lower grill
its not the cheapest way to go. but it fits right in with no cutting and grill and harness take less then an hour to do.
here is the artical they did last year of the install
the grill i have
center light kit
lights
lower speed grill
269.00 grill
87.00 harness
78.00 lights
79.95 lower grill
the grill i have
center light kit
lights
lower speed grill
#29
Afixer... thanks for the great and highly detailed response. I think I am going to go with the GT grill like your original. Where did you purchase the pony emblem you added, and how did you heat it to bend it?
#30
as i posted earlier. i used the pony from my v6 grill it just pops off. then i taped it to the new grill where i wanted it center then center (some may want it offset) anyway once you get it where you like it. look at the bend needed. i took my heat gun ,but a har dryer should work. evenly heat the pony to get it plyable. then i took a paint can and set it on the rounded area and ever so slightly bent it and tested till i got the bend i liked. then set it back on the grill where you want and tape it to it. now set the grill facing down. so you are looking thru the grill to the pony. then i took 4 10/32 nylon screws and CA (crazy glue) glued then to the inside back of the pony thru the mesh. once the screws dry flip the grill back over and remove the tape. now carefully lift off the pony take some 5 min epoxey and fill the back side of the pony with the epoxy covering the bolts. after it dries just set the pony back and use some washers and nylon nuts to attach. and your done.
[IMG]local://upfiles/14019/27BE91200C434757AA03D286A5476287.jpg[/IMG]
[IMG]local://upfiles/14019/CA38E089B21945D58150906E12792AAE.jpg[/IMG]
sorry i have been missing. I am still full steam ahead on the house add on. I'll finish the floor today and demo the garage. start framing the walls tomarrow.
[IMG]local://upfiles/14019/7574A011A4DE462A9C40BE4567E6F96B.jpg[/IMG]
