OK what gives...SCT2 & C&L CAI
So I just received and installed a new SCT2 87, 89 and 93 Octane from a very very reputable provider, and have a few questions.
The CAI went in no problem, once I figured out shrouding. As for the Tune once I removed all the Fuses that had to do with Fans and Fule Pump, I started my upload of the 93 Tune since that is all I ever put in the stang.
Finished completely without a glitch and after turning off the key, and closing the hood, and truk, I jumped right in and pulled the car in to the street and started out on my test drive. I take it slow at first thinking maybe it needs some break in, but then realize that DUH I've had it for a year it's broke in, so I decide at the stop sign to turn off the OverDrive Button and FLOOR IT.. Nada, Nothing like I expected. I expected some tire ripping squewling, but I got nad not even a chirp. So I decide to take it on the road and yes I noticed that while in a semi roll to driving at 45 and hitting it, it feels lke the delay is minimized. So I hit the local shopping store, and get in the empty end of the lot and stop, nice and level, and once again I floor it, I get a little bit of a chirp, but not what I was expecting, so as I'm turning, I think hell for sure I shoul dbe able to rip the tires on a turn, but once again very little amount.. So my question is... Am I expecting too much from this tuner? Should I try to retune it to the 93 again?
Any tips on this would be GREATLY apperciated. As I'm new to this, I'm a bit woried that I have either messed up the install, or i'm expecting too much from my 2005 V6 Automatic.
Thanks,
Chip
Thanks,
Chip
RE: OK what gives...SCT2 & C&L CAI
mine comes tommorrow.maybe you should run gas out and get it from a different station.I dunno.I use shell and hope that is quality enough-I would certainly get as hold of the guys you got it from//A bump for other ideas
Rrrrreaallly? Which speed shop provided your tune? You shouldn't really have any problems getting your wheels to spin, but don't expect a long burnout.. you'll still need to powerbrake. I used the 89 and 91 tunes and can spin the crap out of mine if I'm not careful.
I do have to admit, the car's not like it's a "whole new car" like others say.
Reallly... So I decided one more try behind the wheel.. turn off the overdrive, made sure AC was turned off and still not uch of a tire squeal, more like a chirp and that's about it. Before I give out any shop names as it might just be me that is having an issue and I'm sure the shop will work with me if I call on it, but before doing that I wanted to make sure I was looking for the proper performance. and not living in a dreamland with my v6
Chip
Chip
Well don;t think I have traction control I knwo I don;t have antilock brakes, and doubt I got the traction control assuming there is a TCS button in the blank spot on my dash, along side the 4ways..
So don; think that is it..
Chip
Chip
ORIGINAL: vistapony
Did you turn your TCS off? Even with a tune, if the TCS is on, it will manage your torque and you will not spin much if at all.
Mine burns out for about a car length if I power stall first and let off the break and I don't even have a tuner or cai. All I have is a flowmaster and a K&N Filter. I would think you'rs should be doing a little better.
